It is currently Sat Nov 21, 2026 8:14 am
 Post subject: 9 and 10 Inch Brakes
PostPosted: Thu Jul 06, 2006 11:13 am
Good Day All
After many years I've finally scored a 8-3/4 SBP rear for my beloved '64 Dart. Since come with 10x1-3/4 brakes, will there be any problems with retaining the stock 9" front brakes?
This is a non-power brake car.
Thanks to all who reply..............
PostPosted: Thu Jul 06, 2006 11:28 am
I tired that approach for a while, but under hard braking on my 69 the 10's in the back would lock up when I still had the 9's in front.
I eventually just upgraded to the SBP kelsey Hayes 4 piston deal.
While I was at it I changes tortion Bars, Lower Cont. Arms Added Factory Sway bar.
Only other necessary Change was to Add The prop. Valve and Change the Master Cyl.
Prop. Valves can be had from any Disc Brake a body 67-76
