| 9 and 10 Inch Brakes https://slantsix.org/forum/viewtopic.php?t=18425 |
| Author: | '64 Dart [ Thu Jul 06, 2006 11:13 am ] |
| Post subject: | 9 and 10 Inch Brakes |
Good Day All After many years I've finally scored a 8-3/4 SBP rear for my beloved '64 Dart. Since come with 10x1-3/4 brakes, will there be any problems with retaining the stock 9" front brakes? This is a non-power brake car. Thanks to all who reply.............. |
| Author: | Greg Ondayko [ Thu Jul 06, 2006 11:28 am ] |
I tired that approach for a while, but under hard braking on my 69 the 10's in the back would lock up when I still had the 9's in front. I eventually just upgraded to the SBP kelsey Hayes 4 piston deal. While I was at it I changes tortion Bars, Lower Cont. Arms Added Factory Sway bar. Only other necessary Change was to Add The prop. Valve and Change the Master Cyl. Prop. Valves can be had from any Disc Brake a body 67-76 Greg |
