It is currently Sun Nov 29, 2026 2:45 pm
PostPosted: Mon Jul 10, 2006 3:36 pm
Rod Caps, which way do they go on? The rod has a hole on the right of the engine that oils the camshaft (I think). Does the rod cap go on with the oil dimple on the same side as the rod hole or opposite?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon Jul 10, 2006 4:04 pm
6 Pack Dart
Put them on the rods with both bearing notches together, the notch in the piston goes toward the front of the engine.
