| jets? https://slantsix.org/forum/viewtopic.php?t=18490 |
| Author: | 75duster [ Mon Jul 10, 2006 8:54 pm ] |
| Post subject: | jets? |
does the bbd use the same jets as other carters? |
| Author: | emsvitil [ Mon Jul 10, 2006 9:00 pm ] |
What Carters? Early BBDs and BBS's used same jets Later BBDs used same jets as 4bbls... Not sure of the cutoff year |
| Author: | DusterIdiot [ Mon Jul 10, 2006 9:45 pm ] |
| Post subject: | Mid 70's |
Quote: Not sure of the cutoff year
One carter book specifies all post 1978 Carter's will swap with BBD's...It may actually be a bit earlier than that though I think . -D.Idiot |
| Author: | Greg Ondayko [ Tue Jul 11, 2006 5:55 am ] |
I am not sure of the year either, Just look for the BBD's that have the flat plate above the fuel inlet. Those are the ones that will use the afb/avs jets. If it has a rounded top above the fuel inlet with a lever for the acc. pump that is the early style that has the totally different jets. Greg |
