It is currently Sun Jun 21, 2026 12:24 pm
 Post subject: jets?
PostPosted: Mon Jul 10, 2006 8:54 pm
does the bbd use the same jets as other carters?
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Mon Jul 10, 2006 9:00 pm
What Carters?
Early BBDs and BBS's used same jets
Later BBDs used same jets as 4bbls...
Not sure of the cutoff year
 Post subject: Mid 70's
PostPosted: Mon Jul 10, 2006 9:45 pm
One carter book specifies all post 1978 Carter's will swap with BBD's...It may actually be a bit earlier than that though I think .
PostPosted: Tue Jul 11, 2006 5:55 am
I am not sure of the year either,
Just look for the BBD's that have the flat plate above the fuel inlet.
Those are the ones that will use the afb/avs jets.
If it has a rounded top above the fuel inlet with a lever for the acc. pump that is the early style that has the totally different jets.
