It is currently Tue Nov 17, 2026 9:37 pm
PostPosted: Wed Jul 12, 2006 3:58 am
I have an opportunity to pick up a "B" body 8 3/4 rearend housing which already has the spring perches relocated to 43", but the flange to flange width is 55". The 7 1/4" rearend under the car now is 53.2" flange to flange. Will there be any problems with an extra 0.9" on each side of the car as far as clearance for the wheels?
If not, what size tires will fit?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Wed Jul 12, 2006 5:48 am
Car Model: 1974 W100; 72 Dart
dusters are blessed with big wheel wells (comparitvely). you might need a little more offset. i used a set of mitsubishi FWD wheels on my 1972 Dart a few years back when i did the same swap. i worked with the factory 14" wheels, but not well. (some rubbing in corners and such, probably could have fixed it by rolling up the fender lip)
sb
PostPosted: Thu Jul 13, 2006 7:04 pm
SSRN National Champion
I have a b body 8 3/4 under my race car and run10 inch slicks on 10 inch wheels it works good. But i use stuff that most racers say will not work. It worked damn good at Wilksboro this past weekend. Thanks Ron Parker :D
It Aint Over Until I Win
PostPosted: Fri Jul 14, 2006 3:55 am
Ron,
Is your race car a Duster? What size backspacing on the 10 rims?
bwhitejr
0.090 Shaved Head
PostPosted: Fri Jul 14, 2006 6:04 pm
Hell i doint know just ordered them from jegs i think stock. Stock Slant springs. I put stuff in if it works then i run it if it fails I look what went wrong. Its been in my car for four years so it caint be all that bad. Its a 69 Dart. Thanks Ron Parker :D
PostPosted: Sat Jul 15, 2006 6:48 pm
Ok that was no a very good answer so i went and measred and it look like 5 inches of back space Thanks Ron Parker :D
PostPosted: Mon Jul 17, 2006 5:03 am
OK. I picked up the rear axle assembly yesterday. The thing has 11" brakes on it. Is that good? Seems large. Does that mean 15" wheels?
I also picked up a 741 3.55 SG. I know, I know, it isn't the choice piece, but is anyone else using one?
bwhitejr
0.090 Shaved Head
PostPosted: Mon Jul 17, 2006 5:34 am
The 741 is a good unit nothing wrong with it will do just fine.Thanks Ron Parker :D
PostPosted: Mon Jul 17, 2006 8:11 am
Late model Mustang rims will fit as they have more backspace and are plentiful. I have Mustang 17x8s and 16x8s on my Darts/Valiant.
