It is currently Tue Jun 02, 2026 6:16 pm
 Post subject: Water pump advice
PostPosted: Fri Jul 14, 2006 6:22 pm
Hello to all:
I went to fill up the other day and noticed all of my coolant running out from the car onto the ground. I was able to get her home fast, so that is a plus.
I bought a new water pump, as I assume that that is problem (the coolant was puring out of the bottom of the motor where the pump is).
I guess my question is: does this sound like the pump is bad, or is it a hose or even something else?
If the pump was bad, would all of the fluid have poured out?
Thanks.
PostPosted: Fri Jul 14, 2006 7:18 pm
Take out the thermostat and stick a water hose in. Get underneath the car and watch for leaks.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Jul 14, 2006 7:24 pm
Jeb:
That sounds like excellent advice.
Thanks!
Users browsing this forum: Amazon [Bot], hyper_pak and 17 guests
