Water pump advice
https://slantsix.org/forum/viewtopic.php?t=18575
Page 1 of 1
Author:  Aggronaut [ Fri Jul 14, 2006 6:22 pm ]
Post subject:  Water pump advice
Hello to all:
I went to fill up the other day and noticed all of my coolant running out from the car onto the ground. I was able to get her home fast, so that is a plus.
I bought a new water pump, as I assume that that is problem (the coolant was puring out of the bottom of the motor where the pump is).
I guess my question is: does this sound like the pump is bad, or is it a hose or even something else?
If the pump was bad, would all of the fluid have poured out?
Thanks.
Author:  Jeb [ Fri Jul 14, 2006 7:18 pm ]
Take out the thermostat and stick a water hose in. Get underneath the car and watch for leaks.
Author:  Aggronaut [ Fri Jul 14, 2006 7:24 pm ]
Jeb:
That sounds like excellent advice.
Thanks!
