It is currently Fri Nov 20, 2026 12:05 pm
PostPosted: Tue Jun 06, 2006 12:18 pm
I located a 1967 plymouth valiant in one of our local yards that has a manual steering box on it. But what Id like to know is if the pitman arm
off of the valiant will be ok to use on a '71 duster fitment wise???
PostPosted: Tue Jun 06, 2006 1:24 pm
The steering gearbox is a direct interchange. The pitman arm (and the idler arm) are one-year-only, 1967-only, and will not fit your '71.
PostPosted: Tue Jun 06, 2006 2:34 pm
Thanks Dan. Whats my best bet? A 1970-71 or 72 Duster dart demon or valiant??
PostPosted: Tue Jun 06, 2006 2:38 pm
Pitman + Idler interchange is '68-'72 Dart, Valiant, Demon, Duster plus '68-'69 Barracuda.
PostPosted: Tue Jun 06, 2006 5:51 pm
You can use the pitman arm off the Dusters PS box.
If you use the Mopar 3" adapter (used on Dodge vans), grab the MS pot coupler off the Valiant. If you use the aftermarket adapter, you can use the Dusters PS coupler.
Slant Cecil
PostPosted: Sat Jul 22, 2006 10:54 am
What about a 1966 valiant steering box? Would this work as well???
PostPosted: Sat Jul 22, 2006 11:53 am
Yep, interchange is '62-'72 A- and B-body manual steering box.
PostPosted: Sat Jul 22, 2006 12:11 pm
All the passenger car aluminum manual steering boxes interchange with the exception of C-bodies. The boxes in /6 cars have a bushing on the sector shaft while V8 cars got a needle roller bearing.
PostPosted: Sat Jul 22, 2006 12:14 pm
Not quite.
'62-'72 A- and B-body boxes interchange amongst one another.
'73-up all-body boxes interchange amongst one another and with '62-'72 C-body boxes (larger pitman shaft).
PostPosted: Sat Jul 22, 2006 12:37 pm
Crap, forgot about the large pitman.
