It is currently Fri Nov 20, 2026 2:36 pm
PostPosted: Mon Jul 24, 2006 8:09 am
I see there are thin disks so you can install 5 clutch disks in the stock front clutch drum. Has anyone done that? Results?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Jul 27, 2006 6:59 pm
You can do that with a V8 front drum (I have one in my Slant 904 case), but not sure you can do it in a Slant drum.
PostPosted: Fri Jul 28, 2006 1:28 pm
Is it possible the 3 and 4 disc drums are the same, the difference being the 3 disc drum isn't machined as deep? Has anyone had a 3 disc drum turned on a lathe so 4 discs can fit?
Slant Cecil
