It is currently Fri Nov 20, 2026 12:51 am
PostPosted: Mon Jul 24, 2006 10:10 am
Can you replace seals in this yourself? I don't think the box is shot, but it seems to leak out top where shaft comes out? anyone ever do this job? Lots of hassle to get it in and out, don't want to reinstall same problem...
Does anyone supply rebuilts that will work right? Commenters really welcome, as well as what years are the same...
PostPosted: Tue Jul 25, 2006 5:11 pm
lucas oil makes this stuff called power steering stop leak. I used in my 89 aerostar van to stop the rack from squeeking. and it stoped after a couple of days driving it. I only put in a thimble full to boot. if it stops leaks as well as it stops squeels you should be in business
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Tue Jul 25, 2006 11:02 pm
I resealed my pump a while back. Got the kit from advance auto for around $15. It's fairly easy to do, the hardest part for me was getting the pulley off.
1974 Dodge Dart Custom, 225, 904, now with a Holley 2300...
