It is currently Fri Nov 20, 2026 8:36 am
PostPosted: Tue Jul 25, 2006 5:38 pm
I'm considering getting this 7-1/4 rear end shim, gear settup kit for the pinion seal and cover gasket.
Does this Mopar part #P4876646 7-1/4 rear end shim, gear settup kit work on ALL 7-1/4 rear ends?
I was told it does, but don't want to buy it and find the pinion seal won't work on my 69' 7-1/4 rear end 2.76 ratio.
PostPosted: Wed Jul 26, 2006 7:41 am
Not all 7.25's are internally the same.
around 73 when they started making the LPB 7.25 with 10" brakes they did away with the shims and used side adjusters and c clips like the 8.25.
If yours rear is an original sbp 69 unit that part should work.
