| 7-1/4 rear end shim, gear settup kit https://slantsix.org/forum/viewtopic.php?t=18810 |
| Author: | Galactica5 [ Tue Jul 25, 2006 5:38 pm ] |
| Post subject: | 7-1/4 rear end shim, gear settup kit |
I'm considering getting this 7-1/4 rear end shim, gear settup kit for the pinion seal and cover gasket. Does this Mopar part #P4876646 7-1/4 rear end shim, gear settup kit work on ALL 7-1/4 rear ends? I was told it does, but don't want to buy it and find the pinion seal won't work on my 69' 7-1/4 rear end 2.76 ratio. |
| Author: | Greg Ondayko [ Wed Jul 26, 2006 7:41 am ] |
Not all 7.25's are internally the same. around 73 when they started making the LPB 7.25 with 10" brakes they did away with the shims and used side adjusters and c clips like the 8.25. If yours rear is an original sbp 69 unit that part should work. Greg |
