It is currently Fri Nov 20, 2026 12:01 pm
 Post subject: final drive ratio (3rd)
PostPosted: Thu Jul 27, 2006 7:00 pm
What is the likely 3 rd gear ratio? Is it 1:1? (My car) If unknown what information is needed to know?
Whats the max RPM I should turn a somewhat daily drivers engine? I don't want to kill it over the long haul, but I don't mind some RPMs. I know MPG will go down the higher the RPMs. I travel the highways at about 70 a good portion of the time.
PostPosted: Thu Jul 27, 2006 7:12 pm
With a non overdrive application the final drive is 1.1.
I would go with 3.21 gears if you do any highway driving and do not have an overdrive. 3.55's or lower would be just too dang noisy and it will be a gas hog also. With that long stroke a 225 doesn't like crusing at over 3000 RPM for long periods of time.
82 D150-225/727
02 Dakota-3.9/5 speed
Users browsing this forum: rrither and 2 guests
