It is currently Sat Nov 14, 2026 12:17 am
 Post subject: Carb ID for rebuild kti
PostPosted: Fri Jul 28, 2006 4:52 pm
I have a Holley 1bbl that someone gave me that currently keeps my Slant running. It's in need of a rebuild, throttle shaft doesn't leak so it should be a fine candidate. Where are the numbers that I'll need stamped at to find the model number of it?
-Mike
Daily Driver 72 'Cuda
74 Duster /6
http:www.goodysgotacuda.com
PostPosted: Fri Jul 28, 2006 6:06 pm
The location of the carb type number varies by carb model. Look for a number that starts with "R", then has four digits, then maybe an S, SA, SB, etc. Go look at the pictures in this ad; does your free Holley look at all like this? Or totally different?
PostPosted: Fri Jul 28, 2006 8:34 pm
Thanks, it looks like the one pictured if you ask me.
74 Duster /6
PostPosted: Fri Jul 28, 2006 8:48 pm
Well, you could always save yourself the hassle of IDing the carb you have and just buy one of my new ones! :lol:
Seriously, the ID number you're after is here:
PostPosted: Fri Jul 28, 2006 10:31 pm
haha, those carbs you have are definately very nice. Little out of the league for what my car will see. its a beater, im building a eddie headed 360 for my 'cuda, the 'cuda will donate the 318 to the duster when the time comes. So really, just looking to get the slant running good and sipping gas for the time being :D
Numbers are
1712
6156
now any suggestions on where to get a kit? Thanks :D
74 Duster /6
PostPosted: Sun Jul 30, 2006 6:44 am
NAPA sells a nice carburetor kit for your Holley 1920. Dan probably has part #'s and more.
You should buy one of Dan's Economaster carbs. Old 1920's can be pretty finicky.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sun Jul 30, 2006 8:45 am
I don't much like NAPA's carburetor kits. Standard-Hygrade kits are OK, but I've been impressed with Walker's kits, lately. They seem more complete and more application-specific. You need a 15519A kit.
PostPosted: Sun Jul 30, 2006 10:48 am
Awesome, thanks of course their site doesn't list retail stores. I'll have to try and track a kit down locally. :D
74 Duster /6
PostPosted: Sun Jul 30, 2006 11:10 am
It'll be worth your while to call them up tomorrow and see where you can get one of their kits.
PostPosted: Sun Jul 30, 2006 7:31 pm
I know O'Reilly's carries Walker kits, if you've got one of those locally.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
 Post subject: Ersatz kit...
PostPosted: Sun Jul 30, 2006 9:52 pm
The "mom and pop" store here always stocks Borg Warner kits for the Holley 1920 and 1945 on the shelf (not sure why...when most of their business is Chevy oriented...)...
I have had good luck with the Borg-Warner 10392A kit so far....
