It is currently Wed Nov 18, 2026 10:44 am
PostPosted: Mon Jul 31, 2006 2:59 pm
Exactly where are wheels measured? Is the width measured at the outside of the rim or inside? I'm guessing the outside, but maybe it varies with the manufacturer?
And the diameter? Measured as with a giant outside caliper in the bead channel?
Thanks :D
PostPosted: Tue Aug 01, 2006 1:21 pm
Width is measured to where the tire bead contacts the rim - inside the flange. Diameter is also measured where the bead seats. You can get close enough with a tape measure.
More:
http://www.rsracing.com/tech-wheel.html#backspace
PostPosted: Tue Aug 01, 2006 9:28 pm
Thanks. I needed that!
