It is currently Wed Nov 18, 2026 2:54 am
 Post subject: Rear stance
PostPosted: Tue Aug 01, 2006 9:57 pm
'65 Valiant. I'm sure I read on here that wider shoes on the rear gave a wider track, as the width was added "outboard." However I just discovered that the distance between back plates on my newly acquired LBP, 2.5" shoe equipped, rear end is shorter than on the SBP rear end by at least 2 inches. Normal?
PostPosted: Wed Aug 09, 2006 12:17 pm
1963-1972 7 1/4" A-body backing plate to backing plate = 53.200"
1973-1976 7 1/4" A-body backing plate to backing plate = 51.400"
So yes,if you have a 73-76 a-body 7 1/4" A-body rear it is narrower from bp to bp.
All other dimensions are the same.
Get this book it will help you big time.
Chrysler performance upgrades.
Take care.
JZ
PostPosted: Wed Aug 09, 2006 1:57 pm
You read wrongly. The drum-to-drum width is the same, but the housing itself is shorter to accommodate the wider brakes.
PostPosted: Wed Aug 09, 2006 3:26 pm
Take care.
JZ
Thanks for the tip.
PostPosted: Wed Aug 09, 2006 3:27 pm
Got it. Thanks.
