| Rear stance https://slantsix.org/forum/viewtopic.php?t=18964 |
| Author: | RossKinder [ Tue Aug 01, 2006 9:57 pm ] |
| Post subject: | Rear stance |
'65 Valiant. I'm sure I read on here that wider shoes on the rear gave a wider track, as the width was added "outboard." However I just discovered that the distance between back plates on my newly acquired LBP, 2.5" shoe equipped, rear end is shorter than on the SBP rear end by at least 2 inches. Normal? |
| Author: | Johnny Z [ Wed Aug 09, 2006 12:17 pm ] |
1963-1972 7 1/4" A-body backing plate to backing plate = 53.200" 1973-1976 7 1/4" A-body backing plate to backing plate = 51.400" So yes,if you have a 73-76 a-body 7 1/4" A-body rear it is narrower from bp to bp. All other dimensions are the same. Get this book it will help you big time. Chrysler performance upgrades. Take care. JZ |
| Author: | Joshie225 [ Wed Aug 09, 2006 1:57 pm ] |
You read wrongly. The drum-to-drum width is the same, but the housing itself is shorter to accommodate the wider brakes. |
| Author: | RossKinder [ Wed Aug 09, 2006 3:26 pm ] |
Quote: 1963-1972 7 1/4" A-body backing plate to backing plate = 53.200"
Thanks for the tip.
| Author: | RossKinder [ Wed Aug 09, 2006 3:27 pm ] |
Quote: You read wrongly. The drum-to-drum width is the same, but the housing itself is shorter to accommodate the wider brakes.
Got it. Thanks.
