It is currently Mon Nov 09, 2026 9:04 pm
PostPosted: Wed Aug 02, 2006 12:33 pm
I just bought another Slant engine (73 Dart) with a 904 auto and want to do some work to it. I read either in one of my books or a post here on milling the heads to bring up the compression to about 9.5:1 which also brings up some horsepower. But how much does it bring it up?
If this is true, can I acurately bring a 225 slant up to 200HP without having to put additives in the tank?
I also got the harness to convert my 67 to electronic ignition and the front
disc assembly from the same car. so I will eventually convert to LBP wheels.
What I use the car for is the following:
The car is for cruising.
No racing is intended.
I want to keep the car as original looking as I can.
Currently has a supersix installed, and I would like to continue using this
with some dutra's added later.
next week I will be making some rounds to locate
a machine shop that can do this work for me. Hot tank the block and what ever else is recommended.
I know from reading here that others have already done buildups on a slant so your input will carry a lot of weight on what I would like to do.
I would like to hear some suggestions as to what to ask to have done to it.
More questions to come after hearing from you.
can I put a limit on $1500 into the entire engine buildup?
please offer some ideas.
67 Dart GT convertible
"225 Slant 6"
Super 6 and 2.25" exhaust.
PostPosted: Wed Aug 02, 2006 12:59 pm
Increasing the compression alone will not give you 200hp....adding a cam (mebbe the Erson 270) and some headwork could get you there.
The Super 6 and Dutras would go nicely with that.
$1500 seems reasonable.
PostPosted: Wed Aug 02, 2006 6:00 pm
$1500 seems entirely reasonable. I agree w/ Sandy; shave the head, put in a bigger cam and think about some oversize valves. I can't validate any horsepower figures, but I can say it's an impressive seat of the pants difference.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], DuckDuckGo [Bot] and 4 guests
