It is currently Tue Nov 17, 2026 2:08 pm
PostPosted: Tue Aug 15, 2006 1:14 pm
Was under the hood of my '64 Valiant yesterday, and noticed that the carb was loose on the intake.
So, I tightened it up... and also noticed that it is held-on by bolts instead of studs and nuts...
Most other carbs I've worked-on have the carb mounted with studs & nuts...
Did Chrysler start bolting carbs down in the '60s, or am I confronting an "upgrade" by a previous owner ? :?:
Thanks...
De Soto Frank
PostPosted: Tue Aug 15, 2006 1:16 pm
I've seen 'em both ways. Sounds like your particular application...
...wants studs with good nuts!
PostPosted: Tue Aug 15, 2006 1:58 pm
My '66 had bolts in it as did most of the older motors I have taken apart.
Late '60's on up have always had studs. :shock:
PostPosted: Wed Aug 16, 2006 5:45 am
According to the engine #, my slant is from a '66...
I think I will be changing-over to studs...
De Soto Frank
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 5 guests
