It is currently Tue Nov 17, 2026 3:59 pm
 Post subject: camber cc, anyone
PostPosted: Wed Aug 16, 2006 9:19 am
The last thing I need berfore gitting pistions Is the camber cc. help?
 Post subject: Chamber CC?
PostPosted: Wed Aug 16, 2006 9:30 am
My 72 Slant Six measured 58cc's each on the stock head. Is that what you are looking for?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Wed Aug 16, 2006 9:34 am
You cannot rely on anyone else's chamber CC figure for your own build. There is way too much variability from one cylinder head to the next. You will need to measure the head you intend to use in order to get an accurate figure.
PostPosted: Wed Aug 16, 2006 9:45 am
thank you. I will have it measured
 Post subject: Yeah!
PostPosted: Wed Aug 16, 2006 10:04 pm
Yeah!
I have a 1963 Head that was 68 CC...cut .080 off it and it became a 50cc wonder...
I have a 1976 "600" head on the Hpak duster in the 52 cc range...
I just had a 1974 head redone and it has 60cc chambers after new seats and a .020 cut...
I have a few BL heads that measure in the 53-54 cc range....
Measuring your head is the best information.
PostPosted: Wed Aug 16, 2006 11:23 pm
I measured a SL6 head today and it came in at 59 cc's....Measured a different head last week, it was at 62 cc's... you need to measure the head you have.
PostPosted: Thu Aug 17, 2006 7:04 am
Mine are 39cc's after having 0.100" taken off which comes out to 9.8-1 compression ratio and it cranks 175psi
