It is currently Wed Nov 18, 2026 8:39 am
PostPosted: Mon Aug 28, 2006 4:43 am
I took my small block A-904 apart and I am having trouble getting the thing put back together on spec. The ATSG manual I have only talks about the A904T and the A999 which only had the wide-range planetary gear sets. Mine has the standard planetary gears and has a different placement for the thrust washers surrounding the driving shell. The wide range planetaries have two more thrust washers located opposite ends of the planetaries.
Any help would be appreiated!
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
