Slant Six Forum https://slantsix.org/forum/ |
Just Streetable Cam for Automatic? https://slantsix.org/forum/viewtopic.php?t=19408 |
Author: | bwhitejr [ Tue Aug 29, 2006 9:35 am ] |
Post subject: | Just Streetable Cam for Automatic? |
Does anyone have a recommendation for a just barely streetable cam for an automatic, Duster/Valiant? I want the most cam I can put in a SL6 and just be streetable, not a daily driver, just enough to go to the local burger hang out and race on the weekend. All other mods necessary to support the cam will be made. bwhitejr |
Author: | dakight [ Tue Aug 29, 2006 10:59 am ] |
Post subject: | |
That's kind of what I'm looking for... the fattest cam that I can run with a Super Six, 1.7 / 1.44 valves, stock converter and 3.23 gears. I've been looking at the Erson 270 but wonder if it's a little too much. I don't mind a little lumpiness but I do want it to have good street manners and decent botom end. |
Author: | vynn3 [ Tue Aug 29, 2006 11:16 am ] |
Post subject: | |
Quote: I don't mind a little lumpiness but I do want it to have good street manners and decent botom end.
That's the same thing I look for in a woman...
Author: | argentina-slantsixer [ Tue Aug 29, 2006 11:25 am ] |
Post subject: | |
Quote: Quote: I don't mind a little lumpiness but I do want it to have good street manners and decent botom end.
That's the same thing I look for in a woman...me too! about the erson 270, I haven't installed mine yet (and anyway I'm swapping out the 904 and in a 833) but we installed the erson 270 in a friend's auto car and it's great. I did avdanced it 2º more (that's a total of 6º advanced instead of the built in 4º advanced grind) but it idles good with a 1.7 1.44 MP valves mildly ported (speed ported) head and 3.31 gears. Running recurved dist (8R) and 14 initial with 3.31 gears, and holley 2 bbl 500 cfm |
Author: | Guest [ Tue Aug 29, 2006 11:40 am ] |
Post subject: | |
My Valiant 225 is stock, but my non-Mopar V8 car picked up 3 tenths with a higher stall converter (2500) while using a mild Edelbrock performer cam. I think the cam and converter go hand-in-hand, especially when you say "barely streetable" cam. You will need a higher idle speed and will lose some low end torque and if your car is heavy and your gears are highway oriented, I don't think you'll be happy until you're getting up in rpm's. You probably already know this. |
Author: | Dart270 [ Tue Aug 29, 2006 2:14 pm ] |
Post subject: | |
bwhitejr, You didn't specify if you would stay with a stock converter or not. For any kind of substantial performance with an auto, this is the only way to fly. Lou |
Author: | bwhitejr [ Tue Aug 29, 2006 2:33 pm ] |
What ever it takes to make this thing wail on the strip and be a Slant Six show-off at the burger joint. I just want to be able to drive to the Saturday afternoon hot rod gathering at the burger joint, open some eyes, then Saturday night get some RESPECT. bwhitejr |
Author: | AndyZ [ Tue Aug 29, 2006 2:37 pm ] |
Post subject: | |
That's the same thing I look for in a woman... |
Author: | 75duster [ Tue Aug 29, 2006 7:22 pm ] |
Post subject: | |
on a related subject how wild a build can you get with the stock cam that was used in the early-late 70's?this is supposed to be the cam to use according to the mopar 6 cyl. book |
Author: | CStryker [ Tue Aug 29, 2006 8:05 pm ] |
Post subject: | |
I run an Erson 270 in my pickup and have thus far it has been very streetable, and that's w/ an automatic and stock converter. I also took .090 off the head, which has me up around 9:1 compression, and probably helps keep it drivable. The only thing I will say is that I can definetly tell the difference between my truck being loaded and empty, but I didn't build it to see regular use "as a truck" either. Considering the weight difference between a car and full size pickup, I can't imagine it would cause you problems. In fact, you could probalby go a fair bit more radical and still keep it below the ragged edge. Iirc, other members of have run 280+ durations w/ over .5 inch lifts in cars that saw a lot of street use. |
Author: | bwhitejr [ Wed Aug 30, 2006 3:48 am ] |
In the Mopar Six Cylinder book I think it says that the P4529342 cam is just streetable with a manual transmission. It is 268/208/56 with 0.460 lift ( adv duration, dur @0.050 and overlap). Is this another piece of bad information from the Mopar Six Cylinder Book? That statement had a large influence on my cam choice. bwhitejr |
Author: | bwhitejr [ Wed Aug 30, 2006 7:13 am ] |
Ooops. The cam in the above discussion is the Hyper-Pak cam, not the "342". Hyper-Pak is 276/208/44 lift = 0.43". bwhitejr |
Author: | Dart270 [ Wed Aug 30, 2006 10:31 am ] |
Post subject: | |
I would recommend a 2600-2800 stall converter (9.5 or 10" diam). This will really help on your accel, esp in stoplight action. Unless you hammer it, a converter like this will almost act like stock and mileage will hardly suffer at all. The Erson 270 cam will probably work with a stock converter as it is only 220deg @ 0.050", but will benefit from a higher stall. Good headwork gives a HUGE gain and doesn't affect streetability at all. Spend some good $$ here and you won't regret it. Mike Jeffrey is a great guy with tons of experience on Slant heads. He will be at St. Louis and probably Houston races. Lou |
Author: | featherduster76 [ Thu Oct 26, 2006 6:54 pm ] |
Post subject: | |
Would anyone know a good converter reccomendation for the erson 270? Also would a small cam such as the mopar 244 benefit from a slightly higher stall converter?? |
Author: | Dart270 [ Fri Oct 27, 2006 5:12 am ] |
Post subject: | |
Even a stock cam benefits from a high stall converter, if you are trying to better your track (60 ft mostly) times. The 244 MP works well with a stock conv and I believe you might make a 270 Erson work with a stock converter. I can tell you that even with a 244, you will gain 0.3-0.6 sec in 1/4 mile time with a 2800 stall converter for minimal sacrifice in mileage (~1mpg) and driveability. Lou |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
