It is currently Sun Nov 29, 2026 7:44 am
 Post subject: Grill work
PostPosted: Wed Sep 06, 2006 8:07 pm
I needed to make some room behind the grill for the pusher. I had rear ended someone last fall and the hood latch support was just rubbing the fan as it turned. in order to message things back into the a more correct shape I had to remove the grill and its supports. I figured while it was out I would six any broken spots and repaint it. It was not originally a blacked out grill as far as I know but this is how it turned out. as you can see the metal isn't any where near the shape it should be but it is a huge improvement.
PostPosted: Wed Sep 06, 2006 8:32 pm
Looks prettty good to me.
I saw you and your car in SSRN.
82 D150-225/727
02 Dakota-3.9/5 speed
