It is currently Tue Nov 24, 2026 8:30 am
PostPosted: Thu Sep 14, 2006 4:21 am
My '72 Duster was missing its distributor and mounting plate on my SL 6. I am putting back an electronic distibutor and converting the ignition over. Do I need a mounting plate (kinda looks like a plate with slots on either end) or a clamp assembly like my '80 SL6 to mount it? The FSM shows a plate assembly for the '72, but I am putting a newer distributor on an older style block.
Can I get a plate or clamp assembly locally?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Sep 14, 2006 7:09 am
You can use either style mounting as only the hold down changed and not the engine block or distributor. This is not a normal wear item and should be on the distributor. If not hit up a wrecking yard.
PostPosted: Thu Sep 14, 2006 7:41 am
The later 2 piece style allows for more adjustment when setting the timing. :shock:
