It is currently Tue Nov 24, 2026 12:13 pm
 Post subject: timing gear positions
PostPosted: Fri Sep 15, 2006 11:07 am
alright guys, i just replaced my crank, and its obviously not in the same position as before, plus i also got a new timing set, my question is, how do i set them up? what do i use to position them, and what position do i set them at? pointing to each other? away from each other? pointing the same way? i searched and everything, but i couldnt find an answer that i could understand :roll: so anyway, any help you guys can give me would be great
thanks again,
Evan
if its yours, nobody has to like it except you...
