| Electrical Ground https://slantsix.org/forum/viewtopic.php?t=19847 |
| Author: | 62 alum [ Sun Sep 24, 2006 6:53 pm ] |
| Post subject: | Electrical Ground |
I have a 62 Valiant with a stock aluminum engine. After reading a post on using a ground wire to tie all electrical component to the negative side of the battery instead of using the engine as a ground I decided to have a go at it. After conpleting this I took a short trip and noticed the my amp gauge (stock) now showed a higher charge rate than before. Upon returning home I checked the battery and wiring and found nothing abnormal. The battery, alternator and voltage regulator are all less than 3 month old. Whats up? |
| Author: | 66aCUDA [ Mon Sep 25, 2006 4:49 am ] |
Most likley nothing. You just gave the ampmeter circuit a better ground path to read thru. Ive been in the electrical and electronic busineess 36 years and I see things like this all the time. Frank |
| Author: | 62 alum [ Mon Sep 25, 2006 1:09 pm ] |
| Post subject: | electrical problem |
Thanks for the reply Frank. After driving it today for awhile the amp gauge seems to be returning to normal range. I guess I got a little paranoiac my knowledge of the electrical system is limited. Thanks again |
| Author: | 62 alum [ Mon Sep 25, 2006 1:16 pm ] |
