| Rebuilding a 225 https://slantsix.org/forum/viewtopic.php?t=19866 |
| Author: | Family Scamp [ Mon Sep 25, 2006 6:54 pm ] |
| Post subject: | Rebuilding a 225 |
My first post to this site so suggestions on how to find info etc are welocme. I have two questions: In the Haynes manual it says to replace the drive plate bolts that connect it to the crankshaft if they are removed. Why? I would gladly replace but finding a 7/16 fine 1/2 inch grade 8 bolt is not easy. I will finish rebuilding my 225 several months before the body is done and I attemp to start the engine. Other than using engine grease when I rebuild are there any other concerns or issues I should consider? Thanks Bruce McNulty |
| Author: | Charrlie_S [ Mon Sep 25, 2006 8:13 pm ] |
| Post subject: | Re: Rebuilding a 225 |
Quote: In the Haynes manual it says to replace the drive plate bolts that connect it to the crankshaft if they are removed. Why? I would gladly replace but finding a 7/16 fine 1/2 inch grade 8 bolt is not easy. Thanks Bruce McNulty |
| Author: | Doctor Dodge [ Mon Sep 25, 2006 10:38 pm ] |
Quote: My first post to this site so suggestions on how to find info etc are welcome.
I re-use these bolts all the time and never had a problem. I never saw any warning to not reuse these bolts in the FSM. I have two questions: In the Haynes manual it says to replace the drive plate bolts that connect it to the crankshaft if they are removed. Why? I would gladly replace but finding a 7/16 fine 1/2 inch grade 8 bolt is not easy... Quote: I will finish rebuilding my 225 several months before the body is done and I attemp to start the engine. Other than using engine grease when I rebuild are there any other concerns or issues I should consider?
Tape-off / plug any openings.Thanks Bruce McNulty Keep the engine in a dry place and turn it over with a wrench ever month or so. DD |
