It is currently Wed Nov 25, 2026 9:20 pm
 Post subject: Rebuilding a 225
PostPosted: Mon Sep 25, 2006 6:54 pm
Car Model: 1973 Plymouth Scamp
My first post to this site so suggestions on how to find info etc are welocme.
I have two questions:
In the Haynes manual it says to replace the drive plate bolts that connect it to the crankshaft if they are removed. Why? I would gladly replace but finding a 7/16 fine 1/2 inch grade 8 bolt is not easy.
I will finish rebuilding my 225 several months before the body is done and I attemp to start the engine. Other than using engine grease when I rebuild are there any other concerns or issues I should consider?
Bruce McNulty
 Post subject: Re: Rebuilding a 225
PostPosted: Mon Sep 25, 2006 8:13 pm
Bruce McNulty
My 1st sugestion, is to trash the Haynes manual, and get the proper Factory Service Manual.
PostPosted: Mon Sep 25, 2006 10:38 pm
My first post to this site so suggestions on how to find info etc are welcome.
In the Haynes manual it says to replace the drive plate bolts that connect it to the crankshaft if they are removed. Why? I would gladly replace but finding a 7/16 fine 1/2 inch grade 8 bolt is not easy...
I re-use these bolts all the time and never had a problem. I never saw any warning to not reuse these bolts in the FSM.
Bruce McNulty
Tape-off / plug any openings.
Keep the engine in a dry place and turn it over with a wrench ever month or so.
