It is currently Fri May 15, 2026 8:32 am
 Post subject: D-100 /6 to /6 swap
PostPosted: Fri Sep 29, 2006 5:38 pm
In a nut shell my motor in my 85' D100 is shot. I found a good running /6 in a 81' Van. Auto with A/C. I would like to swap my 6 with this engine. Question is, will there be anything I need to change or is this a pretty clean swap? Keep in mind my truck has a A833OD and the van is a an auto.
Highway
85' D100
225cid
A833OD
PostPosted: Fri Sep 29, 2006 5:53 pm
Direct swap.
PostPosted: Fri Sep 29, 2006 5:55 pm
Sweet!
Thanks Dan
85' D100
225cid
A833OD
PostPosted: Fri Sep 29, 2006 6:20 pm
Don't forget the pilot bearing in the crank! Hopefully the crank is drilled and reamed for the bushing. If not you can use a roller pilot bearing for a late model pickup.
