It is currently Fri Nov 27, 2026 1:07 am
PostPosted: Mon Oct 02, 2006 7:44 pm
If I bore the 225 .080 - .100 over what head gasket options do I have?
PostPosted: Tue Oct 03, 2006 6:43 am
Felpro composite gasket is 3.50 bore, so will work up to 0.100" overbore.
There is also an Aussie "permaseal" head gasket with 3.66" bore, which can handle anything. Hard to get here, though. I did a group buy a while back, but am burned out at the moment.
PostPosted: Tue Oct 03, 2006 10:23 am
Can you still get the steel shim gaskets?
Jess
PostPosted: Tue Oct 03, 2006 2:58 pm
I have 2 of the aussie permaseal gaskets - project went a different route, I can sell you one of mine if you wish.
PostPosted: Tue Oct 03, 2006 8:49 pm
When you say they can handle anything, what do you mean? Anysize bore and or any compression ratio. I plan to run some nitrous on this motor.
PostPosted: Wed Oct 04, 2006 4:50 am
Jess
Yes, but not readily. Need to find some NOS still on the shelf, somewhere. Some of us have a small stash. I have sold some of mine from time to time, but don't want to sell any more right now. Not many left, and might need them.
PostPosted: Wed Oct 04, 2006 5:50 am
Jess
Call Bill Hupke at 'The chicago Connection' in Chicago. He bought the last batch that were in the sales system, and may have some left. 773/229-0655.
PostPosted: Wed Oct 04, 2006 5:55 am
Is one head gasket just as good as another when it comes to sealing? Whats the difference between the permaseal, steel shim type and the Felpro gaskets?
PostPosted: Wed Oct 04, 2006 7:11 pm
the steel shim gaskets are about .020 thinner and therefore yield a higher comression ration.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Oct 04, 2006 7:21 pm
I have 2 or 3 of the factory steel shim gaskets still in the Chrysler boxes if anyone is interested.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Wed Oct 04, 2006 10:13 pm
Does one tend to be stronger or last longer than the others? If that happens to be the factory steel shim then I'd be interested in one!
PostPosted: Thu Oct 05, 2006 4:24 am
If you run the steel shim gasket, make sure the head and deck surface is dead flat. They are not very forgiving about warpage. That is one reason why the after market gaskets are thicker. Thay are more forgiving about a slight amount of warp.
PostPosted: Thu Oct 05, 2006 1:36 pm
Very true, it also helps to get some of the spray Mopar uses on the Neon heads for the steel shims gaskets, but a fresh deck & head surface is a must.
Jess
PostPosted: Thu Oct 05, 2006 1:37 pm
HyperValiant
If you could PM me with a price.
Jess
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 33 guests
