It is currently Mon Nov 16, 2026 11:34 am
PostPosted: Mon Oct 09, 2006 8:38 pm
Where can one buy a 904A with mods and torque converter complete? A bolt in and your done. Or is it not possable? I see lots of 727's and 904's but no 904A's
PostPosted: Tue Oct 10, 2006 4:35 am
Are you looking for a New, Used, private deal, or profesionally built unit?
There are many "race" trans shops, that can do this for you. I can't recomend any trans shops, as I do my own, but can recomend a couple of converter builders.
The biggest problem with finding one already done, is the fact of it needing to be a six cyl case. Just not that many floating around out there.
PostPosted: Tue Oct 10, 2006 5:36 am
I am looking for one that has some sort of warranty. A private deal is OK if a few people can vouch for their creditably.
PostPosted: Tue Oct 10, 2006 9:46 am
Try Rhino Engines- http://www.rhinoengines.com They have a 3 year warranty on their stuff. Otherwise, I would go check out your local tranny shop. You will be surprised what some of the older shops have on the back shelves!
Russ
