It is currently Mon Nov 16, 2026 1:00 am
PostPosted: Sat Oct 14, 2006 3:44 pm
Hello,
Does anyone know if the K-Member from a 1974 slant-six Duster is the same for the 1975 slant six Dodge Dart Sport? I measured the basics and they look the same. The motor block casting # is also the same.
Thanks,
Jim Roberts
PostPosted: Sat Oct 14, 2006 4:34 pm
Yep, they are the same.
 Post subject: The magic spool years...
PostPosted: Sat Oct 14, 2006 7:11 pm
Your interchange is basically 1973-1976
Good luck,
p.s. you could also swap in a 1967-1972 k-member, but why go back to sandwich mounts?
PostPosted: Sun Oct 15, 2006 5:13 am
DI is correct on 67-72 being able to use the 73-76 frames. Once swapped a 74 slant 6 k frame to a 67 Barracuda. Fit and worked like it was made for it.
PostPosted: Sun Oct 15, 2006 6:25 am
Another nice feature on the '73+up k-frames is the swaybar passes thru the frame and the mounts tuck neatly between the "legs of the K" (for lack of a better name.:oops:) Makes for better ground clearance and I would guess a stiffer bar due to the short arm length.
-James
