| K-Member interchangability question for 75 Dart https://slantsix.org/forum/viewtopic.php?t=20230 |
| Author: | Jim Roberts [ Sat Oct 14, 2006 3:44 pm ] |
| Post subject: | K-Member interchangability question for 75 Dart |
Hello, Does anyone know if the K-Member from a 1974 slant-six Duster is the same for the 1975 slant six Dodge Dart Sport? I measured the basics and they look the same. The motor block casting # is also the same. Thanks, Jim Roberts |
| Author: | SlantSixDan [ Sat Oct 14, 2006 4:34 pm ] |
Yep, they are the same. |
| Author: | DusterIdiot [ Sat Oct 14, 2006 7:11 pm ] |
| Post subject: | The magic spool years... |
Your interchange is basically 1973-1976 Good luck, -D.Idiot p.s. you could also swap in a 1967-1972 k-member, but why go back to sandwich mounts? |
| Author: | 65 dartman [ Sun Oct 15, 2006 5:13 am ] |
DI is correct on 67-72 being able to use the 73-76 frames. Once swapped a 74 slant 6 k frame to a 67 Barracuda. Fit and worked like it was made for it. |
| Author: | james longhurst [ Sun Oct 15, 2006 6:25 am ] |
Another nice feature on the '73+up k-frames is the swaybar passes thru the frame and the mounts tuck neatly between the "legs of the K" (for lack of a better name. -James |
