It is currently Mon Nov 30, 2026 11:46 am
 Post subject: Roller Rockers & Valves
PostPosted: Tue Oct 24, 2006 3:06 pm
Hey guys, Is there anywhere to find roller rocker arms? Or aftermarket rockers period? Also, Waht are my valve choices? I would like to have around a 1.85 intake, and whatever size Exhaust will fit with that.
Mopar BB/RB valves? Chevy valves? Or even :shock: Ford valves?!?!
Any help is greatly appreciated!!
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Tue Oct 24, 2006 3:33 pm
SSRN National Champion
Cox Bros Columbus Ohio for the roller rocker arms great piece been on my race car two years. Valves i doint know if you can put that big of intake valve in a Slant but im not a engine builder. Thanks Ron Parker :D
It Aint Over Until I Win
PostPosted: Tue Oct 24, 2006 6:56 pm
Valve size will depend on how much overbore you have.
For 0.030-0.060" over, the SB Ford valves 1.78/1.46 or SB Chev valves 1.72/1.50 are both about the right length and just require 5/16" valve guides installed.
PostPosted: Wed Oct 25, 2006 3:28 am
I have used the Mopar B- RB exhaust valves, they are a little longer but have tha 3/8" guide size.
I use the 1.81 Ex. as the intake and the the early 361 / 383 1.6 exhaust valve, trimmed down to fit the SL6 overbore. (trim to appx 1.5 head diameter)
If the SL6 head you are using needs guides, go to the "brand X" valves as suggested above.
