It is currently Thu Jun 11, 2026 6:27 pm
 Post subject: z bar interchange??
PostPosted: Sun Nov 05, 2006 3:17 pm
Are all the slant 6 Z bars the same?? Will a 67 Z bar for a 3 speed work in a 67 with a O/D 4 speed?
Thanks :D
PostPosted: Sun Oct 07, 2012 7:35 am
Car Model: 1962 Dodge Lancer GT Black/Red
As in What other models will interchange with 62 Lancer slant six three speed combination?
Thx, Ray
PostPosted: Sun Oct 07, 2012 7:41 am
67 I would guess the z-bar would be the same, and MG I cant answer your question on the interchange, but maybe someone else will....
MRO....
PostPosted: Sun Oct 07, 2012 7:44 am
Thank you. I noticed this one had gone unanswered. It was the only reference i found in my search. So I tried to resurrect it. :)
PostPosted: Sun Oct 07, 2012 8:38 am
I did find that the 63 to 66 small bell housing A bodies use the same z-bar for 3 and 4 speed applications. I think I can safely assume the 62 will match that. knowing that the a bodies became wider in the engine compartment may exclude the interchange with the newer a bodies along with the fact that the bell housing diameter changed as well.
 Post subject: Not sure but...
PostPosted: Sun Oct 07, 2012 9:16 am
The 67-76 slant six Zbar is for the wide bodies, 63-66 is a little different in width. Never have pulled one out of an early car to see what length the 60-62 is.
PostPosted: Sun Oct 07, 2012 11:18 am
Thank you for the confirmation Rob. Just ordered a new one from Laysons.
