| z bar interchange?? https://slantsix.org/forum/viewtopic.php?t=20624 |
| Author: | 67Post [ Sun Nov 05, 2006 3:17 pm ] |
| Post subject: | z bar interchange?? |
Are all the slant 6 Z bars the same?? Will a 67 Z bar for a 3 speed work in a 67 with a O/D 4 speed? Thanks |
| Author: | MotoGrey [ Sun Oct 07, 2012 7:35 am ] |
| Post subject: | Does anyone know the interchange info for A body Z bars? |
As in What other models will interchange with 62 Lancer slant six three speed combination? Thx, Ray |
| Author: | Mroldfart2u [ Sun Oct 07, 2012 7:41 am ] |
67 I would guess the z-bar would be the same, and MG I cant answer your question on the interchange, but maybe someone else will.... |
| Author: | MotoGrey [ Sun Oct 07, 2012 7:44 am ] |
Thank you. I noticed this one had gone unanswered. It was the only reference i found in my search. So I tried to resurrect it. |
| Author: | MotoGrey [ Sun Oct 07, 2012 8:38 am ] |
I did find that the 63 to 66 small bell housing A bodies use the same z-bar for 3 and 4 speed applications. I think I can safely assume the 62 will match that. knowing that the a bodies became wider in the engine compartment may exclude the interchange with the newer a bodies along with the fact that the bell housing diameter changed as well. |
| Author: | DusterIdiot [ Sun Oct 07, 2012 9:16 am ] |
| Post subject: | Not sure but... |
The 67-76 slant six Zbar is for the wide bodies, 63-66 is a little different in width. Never have pulled one out of an early car to see what length the 60-62 is. -D.Idiot |
| Author: | MotoGrey [ Sun Oct 07, 2012 11:18 am ] |
Thank you for the confirmation Rob. Just ordered a new one from Laysons. |
