It is currently Sat Jan 11, 2025 4:00 am
 Post subject: Solid motor mounts
PostPosted: Sun Nov 12, 2006 12:20 am
I know there is not a whole lot of interest, but I fabbed a pair of solid mounts for my '66 Valiant today. My stock mounts had sagged and twisted, plus, I want to get rid of my torque link to free up some space.
Total list of materials:
2-4" sections of 2X2X/1/4" box tubing
3-1/2X1 bolts
3-3/8X1 bolts
3-1/2" locknuts
3-3/8" locknuts
Welder (optional)
I just eyeballed the location for the holes, drilled them, and tightened the bolts up for a test fit in the car. When I was happy, I had the 2 1/2" bolts that go through the K frame welded in so as to avoid needing 2 wrenches. :shock:
 Post subject: Re: Solid motor mounts
PostPosted: Sun Nov 12, 2006 4:15 am
3-1/2X1 bolts
3-3/8X1 bolts
3-1/2" locknuts
3-3/8" locknuts
Welder (optional)
Post some pics if you can and do not mind..
69 valiant
PostPosted: Sun Nov 12, 2006 8:40 am
How do you like em so far? how well does the chassis absorb the vibration?
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sun Nov 12, 2006 6:06 pm
I did the same thing many years ago on a '66 dart with a 318 and I still have those mounts. I used 2x4 channel iron and 1/8" plate.
The vibration was reasonable.
 Post subject: solid motor mounts
PostPosted: Sun Nov 12, 2006 7:08 pm
Where are the pictures?!?! :lol:
My rubbers are shot, and I would prefer to go back with solid. No one makes 'em of course... I think solid are easier on the drivtrain.
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Sun Nov 12, 2006 7:23 pm
I run 1 Solid Mount On the Drivers Side - I had Problems With The usual Saggy Mounts, etc. But My Motor also Was moving Back (also Due To a Bad Trans Mount) And it was throwing my clutch adjustment all out of wack.
I bought A Solid A Body/ A Engine Moroso Mount and Shimmed it About 3/16" Higher. Works Perfect. They come in pairs because aparrently The L and R Engine Mounts for 67-72 A Body / A engines are the same Left to right.
I Got rid of the torque strap too.
Still Use the rubber mount on the Right.
PostPosted: Sun Nov 12, 2006 7:29 pm
Stupid question(s):
1. What is a torque strap?
2. Wouldn't 2 kinds of mounts,(rubber/solid) cause cracking in the solid? because of the uneven load?
PostPosted: Mon Nov 13, 2006 5:10 am
Sorry, no pictures, and they have only been in the car on a setup block. I may get a motor in the car next weekend though.
These things are incredibly simple to make. If I can visualize and build them, anyone can. :D
A torque link is a bar that runs from the left side of the motor to the chassis to keep the engine from torquing over on the mounts. :shock:
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot], Majestic-12 [Bot] and 8 guests
