It is currently Sun Nov 15, 2026 10:12 pm
PostPosted: Wed Nov 22, 2006 8:36 am
I just scored a 225 and trans from an early setup with pushbutton. Im going to go get a ride in the car before he pulls the drivetrain, so I can decide which pieces feel stronger/ smoother, cuz the stuff in my car aint so bad, so I might keep my trans.
So if this trans seems to shift better than mine, can I run it with my column shift?
thanks
madam im adam
PostPosted: Wed Nov 22, 2006 8:39 am
No, you cannot.
PostPosted: Wed Nov 22, 2006 11:33 am
thanks dan. I guess it'll be less work to pull the engine without the trans anyway. I'll post in the for sale section and see if anybody needs the PB trans for cheep!
madam im adam
PostPosted: Wed Nov 22, 2006 4:06 pm
FYI,
A 60-67 "small crank hub" SL6 engine is not going to bolt-up to your 68 and later auto trans. :cry:
