It is currently Mon Nov 16, 2026 12:54 am
PostPosted: Sun Nov 26, 2006 5:27 am
how critical is the 111-113 degrees for the accelerator pedal? Is this just to make sure you have it away from the floor? My linkage came loosefrom the throttle shaft --& tranny downshifts were not good-- just curious how close you need to be to the FSM position -- I'm at roughly 145 now. Thanks
PostPosted: Sun Nov 26, 2006 7:24 am
The rod linkage works best when everything's set up the way the book says.
