| 62-66 rod linkage adjustment https://slantsix.org/forum/viewtopic.php?t=20880 |
| Author: | VDART [ Sun Nov 26, 2006 5:27 am ] |
| Post subject: | 62-66 rod linkage adjustment |
how critical is the 111-113 degrees for the accelerator pedal? Is this just to make sure you have it away from the floor? My linkage came loosefrom the throttle shaft --& tranny downshifts were not good-- just curious how close you need to be to the FSM position -- I'm at roughly 145 now. Thanks |
| Author: | SlantSixDan [ Sun Nov 26, 2006 7:24 am ] |
The rod linkage works best when everything's set up the way the book says. |
