It is currently Tue Nov 17, 2026 6:56 am
PostPosted: Wed Nov 29, 2006 7:27 pm
Got a chance to get one for cheep- not sure what would make or break the deal if I tried to adapt it. input shaft length? bellhousing configuration? Shifter Location?
thanks
Kevin
madam im adam
PostPosted: Tue Dec 05, 2006 4:20 pm
Thats the same trans as in my car. Its called a RAP. Light,compact,shifts well and a little light for drag racing. My car makes about 200 hp and the trans seems fine. If you can live with a 7.25 rear end this box may work for you,
Heres more info: http://slantsix.org/forum/viewtopic.php?t=11497
PostPosted: Fri Dec 08, 2006 4:47 pm
cool thanks Ill pick it up if I still can!
madam im adam
 Post subject: Ford 5 speed
PostPosted: Sat Dec 23, 2006 11:34 pm
What about the Borg Warner unit that came in the Mustangs...The 4 cylinder and 6 cylinder 5 speeds?
Considering that the Early Rangers and Mustangs both came with the 2.3 litre engines and 5 speeds I would think the transmissions are pretty close to being the same.
I have a T5 out of a Z28 Camaro and I was looking at it and thinking that it would be perfect for a Dart with a slant...Might have to enlarge a couple holes to get the bell housing to bolt to the transmission...No big deal
You can find this transmission in S-10 trucks they are plentiful and tough...The t-5 borg warner is considered tough enough for 300 horse power without problems...
Users browsing this forum: Amazon [Bot] and 5 guests
