It is currently Sun Nov 15, 2026 10:28 pm
PostPosted: Thu Nov 30, 2006 7:56 am
Is there a trick to removing the front seat on a 71 Dodge Dart? I wasn't sure if it simply bolts down from the inside. Do I need to get under the car to remove it? Thanks guys.
PostPosted: Thu Nov 30, 2006 10:10 am
4 nuts on the underside hold it in via studs through the floorboards. IIRC they take a 1/2 deepwell.
PostPosted: Thu Nov 30, 2006 12:01 pm
2 bolts on each side of the bench, 4 bolts on each bucket.
Don't forget to get the seatbelts out of the way too.
