It is currently Sun Nov 15, 2026 8:18 am
 Post subject: Modern Wheels
PostPosted: Thu Dec 07, 2006 2:28 pm
:idea:
Most Of Our Cars Run Ma Mopar's 5 on 4" Bolt Pattern Right?... I Was Cruising Craig's List The Other Day For Some Fresh Rollers And Found That A Lot Of The Newer Imports Sport A 5 on 100mm Pattern... The Difference Between The Two Is Slight: (Without Getting Real Precise ) Only 1.5mm!
Is This Still Too Much Play?
Still Need To Do Some Research On The Hole In The Center Of The Newer Wheels ( Is There A Technical Name? ) .....
Thinking Back, I Noticed Some Tall Lexus Alloys On A B-Body Last Spring, Never Was Able To Get Too Much Info From The Owner Though...
PostPosted: Thu Dec 07, 2006 2:48 pm
Front-wheel-drive wheels do not fit or work correctly or safely on rear-drive cars, and 100mm is not close enough to 4" to be a safe substitute.
Sorry, I know they're temptingly common, but this won't work.
