| Modern Wheels https://slantsix.org/forum/viewtopic.php?t=21006 |
| Author: | sethmcneil [ Thu Dec 07, 2006 2:28 pm ] |
| Post subject: | Modern Wheels |
Most Of Our Cars Run Ma Mopar's 5 on 4" Bolt Pattern Right?... I Was Cruising Craig's List The Other Day For Some Fresh Rollers And Found That A Lot Of The Newer Imports Sport A 5 on 100mm Pattern... The Difference Between The Two Is Slight: (Without Getting Real Precise ) Only 1.5mm! Is This Still Too Much Play? Still Need To Do Some Research On The Hole In The Center Of The Newer Wheels ( Is There A Technical Name? ) ..... Thinking Back, I Noticed Some Tall Lexus Alloys On A B-Body Last Spring, Never Was Able To Get Too Much Info From The Owner Though... |
| Author: | SlantSixDan [ Thu Dec 07, 2006 2:48 pm ] |
Front-wheel-drive wheels do not fit or work correctly or safely on rear-drive cars, and 100mm is not close enough to 4" to be a safe substitute. Sorry, I know they're temptingly common, but this won't work. |
