It is currently Mon May 18, 2026 7:22 am
 Post subject: neutral safety switch
PostPosted: Fri Dec 08, 2006 11:42 am
Does anyone know the part number for a '63 valiant neutral safety switch? Auto trans. Thanks.
PostPosted: Fri Dec 08, 2006 12:48 pm
Part number is N/A because this switch has been N/A for years. You can get it as # T-257 from Andy Bernbaum for $24.50. You can also get it from Pat Blais, tflitepatty@verizon.net , price unknown.
PostPosted: Sat Dec 09, 2006 9:32 am
according to a couple of sources there is still some NOS available. They list PN 1704283, '55-'65 Plymouth. I was looking to verify if this is accurate.
PostPosted: Sat Dec 09, 2006 9:45 am
1704 283 is the factory P/N for the '56 through '64 switch ('65-'68 is a different switch).
Where are you planning on shopping for this switch, besides the two known-good sources I already gave you?
PostPosted: Sat Dec 09, 2006 7:06 pm
65 thu 84 should be the same, I can get these for $7.95 a piece. But I dont know about the earlier switches.
Jess
PostPosted: Sat Dec 09, 2006 7:20 pm
Nope!
'56-'64 is one switch (single-terminal)
'65-'68 is another switch (single terminal, different switch)
'69-up is the 3-terminal switch you're thinking of.
PostPosted: Sun Dec 10, 2006 4:54 am
Dan is quite correct.
When I installed a 64 PB valve body in a 65 trans, I had to change the switch, also.
PostPosted: Mon Dec 11, 2006 8:16 am
They were both on EBAY.I bought one. There is one left.
