| neutral safety switch https://slantsix.org/forum/viewtopic.php?t=21017 |
| Author: | Bing Kunzig [ Fri Dec 08, 2006 11:42 am ] |
| Post subject: | neutral safety switch |
Does anyone know the part number for a '63 valiant neutral safety switch? Auto trans. Thanks. |
| Author: | SlantSixDan [ Fri Dec 08, 2006 12:48 pm ] |
Part number is N/A because this switch has been N/A for years. You can get it as # T-257 from Andy Bernbaum for $24.50. You can also get it from Pat Blais, tflitepatty@verizon.net , price unknown. |
| Author: | Bing Kunzig [ Sat Dec 09, 2006 9:32 am ] |
according to a couple of sources there is still some NOS available. They list PN 1704283, '55-'65 Plymouth. I was looking to verify if this is accurate. |
| Author: | SlantSixDan [ Sat Dec 09, 2006 9:45 am ] |
1704 283 is the factory P/N for the '56 through '64 switch ('65-'68 is a different switch). Where are you planning on shopping for this switch, besides the two known-good sources I already gave you? |
| Author: | LUCKY13 [ Sat Dec 09, 2006 7:06 pm ] |
65 thu 84 should be the same, I can get these for $7.95 a piece. But I dont know about the earlier switches. Jess |
| Author: | SlantSixDan [ Sat Dec 09, 2006 7:20 pm ] |
Quote: 65 thu 84 should be the same
Nope!'56-'64 is one switch (single-terminal) '65-'68 is another switch (single terminal, different switch) '69-up is the 3-terminal switch you're thinking of. |
| Author: | Charrlie_S [ Sun Dec 10, 2006 4:54 am ] |
Dan is quite correct. When I installed a 64 PB valve body in a 65 trans, I had to change the switch, also. |
| Author: | Bing Kunzig [ Mon Dec 11, 2006 8:16 am ] |
They were both on EBAY.I bought one. There is one left. |
