It is currently Mon Jun 15, 2026 8:37 pm
PostPosted: Fri Dec 08, 2006 1:20 pm
Guys-
Second "how easy is it" post. Same 74 Dart swinger needs it's new exhaust manifold installed. I've never done it. How easy is it? Do I need special tools/knowledge?
Evan
PostPosted: Fri Dec 08, 2006 1:27 pm
Your first time? It's a bear.
The fifth or sixth time? A light chore.
Getting to the blind nut/stud underneath the choke pocket is the fun part. Once you've done it a few times and picked up a few tricks, it's not that big of a deal.
Read this for more info:
http://www.slantsix.org/articles/manifo ... unting.htm
vm
PostPosted: Fri Dec 08, 2006 7:52 pm
If it's the original manifold, be ready for the inevitable broken-off rusty studs.
My suggestion is to acquire the necessary 1/4" drive socket, extension, and swivel joint adapter that can get to the elusive nut vynn is referring to.
Good luck,
Jerry
