It is currently Tue May 12, 2026 11:51 am
PostPosted: Tue Dec 12, 2006 12:11 am
Hey guys,
I am looking at some older A-Bodies to get back into Mopars. Mainly 63-66 Valiants/Darts/Barracudas. I am searching for a manual transmision
and keep finding alot of these cars with a 3 speed standard on the tree. I ran a search on here for some info, but came up short for what I was looking for. I would like the shifter on the floor! I was wondering if I could buy one of these universal shifters from summit:
http://store.summitracing.com/egnsearch ... wordSearch
And use that to do the conversion if they will work. Some of the posts I found mentioned you will need a floor hump welded in, is this required to convert with an aftermarket shifter? I am not sure which 3 speeds came in these cars, could you gimme some advice on the swap guys?
-Mike
 Post subject: shifters like those?
PostPosted: Fri Dec 15, 2006 5:31 pm
Car Model: 1974 W100; 72 Dart
dont do it mike. those things are junky and won't last. 3 on the tree is kinda' cool, too. FEW younger people even know it exists.
definitely not worth hacking up a car to do....now, if you are putting a 5 speed in there.....
sb
PostPosted: Fri Dec 15, 2006 6:02 pm
Thanks for the reply, I guess it is cool to see a column shifted car, I have only seen one in action in my short life! Ill keep my eyes peeled for a nice old A-body.
-Mike
 Post subject: Look around...
PostPosted: Fri Dec 15, 2006 7:59 pm
You just need to find a "hump" for the shifter, or make a custom one...
Then get yourself a bellhousing and A-230 3 speed out of a 1974-1976 A-body or a 1976-1979 F-body (these had floor shifted trannies, and the first gear is synchroed, and the ratio is "kind" for a manual tranny)
Usually the 1974-1976 cars that had this set up also came with disk brakes and an 8.25" rear too (in 3.21 ratio...)
Users browsing this forum: Bing [Bot] and 11 guests
