It is currently Tue Nov 17, 2026 7:16 am
 Post subject: 1965 barracuda body work
PostPosted: Fri Dec 29, 2006 10:38 pm
I have a friend who wants to remove his engine compartment fender wells because of an accident and install some from a donor car. Has anyone done this before? Is it worth it? I know that his car is a unibody and is welded and not bolted together. I am helping him. Are we getting in over our heads or should we continue with the work. Thanks in advance.
PostPosted: Sat Dec 30, 2006 10:49 am
Do you know how to weld? Do you have access to replacement sheet metal? Can you fabricate replacement panels?
The '65 Cuda is not exactly on the top of the list for the sheetmetal replacement business.
